[GRASS-user] fix for broken wxGUI on Linux
Markus Metz
markus.metz.giswork at googlemail.com
Mon Dec 14 04:42:44 EST 2009
Markus Neteler:
> Removing both vdigit and nviz from the GISBASE/wxGUI subdirectories
> "solves" the problem. This indicates that SWIG is causing the problem.
> Using swig 1.3.40.
A bit better here on Fedora 12, also using swig 1.3.40. The wxGUI nviz
works, the wxdigitizer crashes. Removed swig 1.3.40, got swig 1.3.29,
patched that with the patch provided in the wxPython source code, now
everything is working, no errors. One warning at grass startup:
warnings.warn("wxPython/wxWidgets release number mismatch")
because Fedora 12 comes with wxBase and wxGTK 2.8.10 and wxPython 2.8.9,
but it works.
Ubuntu 9.10 uses wx packages 2.8.10 throughout together with swig
1.3.36, both wx nviz and wx digitizer work just fine.
Markus M
