[GRASS-user] Re: v.breach addon
M S
mseibel at gmail.com
Mon Dec 14 15:24:38 EST 2009
Kubuntu 9.10 64bit, using GRASS 6.5.
I ran v.breach on a stream network extracted with r.stream.extract.
It runs through the program, and puts up an error dialogue at
v.parallel. Attached is the log file. It looks like a negative
number is being passed to v.parallel. I saw in the documentation this
might be a problematic module in the script for non-metric coordinate
system. Below is the portion of the output box from the module. Note
the error 11 lines down.
Building topology for vector map <breach_pt_segm_2l_r_tmp_5636_0_v_breach_sh>...
Registering primitives...
100 primitives registered
259 vertices registered
Building areas...
0 areas built
0 isles built
Attaching islands...
Attaching centroids...
Number of nodes: 100
ERROR: value <-0.00001> out of range for parameter <distance>
Number of primitives: 100
Number of points: 0
Number of lines: 100
Number of boundaries: 0
Number of centroids: 0
Legal range: 0-100000000
Description:
Creates parallel line to input vector lines.
Keywords:
vector, geometry
Should I look in the script for this portion, and check if it is a
metric issue? or does this seem like a different problem?
Thanks,
Mark
2009/12/14 Maciej Sieczka <msieczka at sieczka.org>:
> Luís Ferreira pisze:
>> I used v.breach with both SQLite and dbf, with ETRS89 metric negative
>> coordinates, from 20m to 2m resolution and worked fine.
>> System: Ubuntu 9.10 Karmic Koala, 64 bits, GRASS 6.4SVN.
>> But I remember to see some warnings like yours. Are these warnings
>> critical? Visually, the interpolated DEMs with v.surf.rst are
>> coherent.
> I'll let you know next time I take a hobbyist look at v.breach. But I
> really don't know when it will be.
> Good luck.
> Maciek
>> On Mon, 2009-12-14 at 04:57 +0100, Maciej Sieczka wrote:
>>> @Luís: I applied most your of patch. Thanks! Are you sure that's
>>> all errors? I keep on getting warnings like:
>>> WARNING: Unable to get point on line: cat = 1 offset = 2.831711
>>> (line length = 0)
>>> at v.segment calls in the script, and a crash at v.in.ascii.
> Maciej Sieczka
> http://www.sieczka.org
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20091214/9f9cf982/v.breach-0001.obj
