[GRASS-user] Re: v.breach addon
Maciej Sieczka
msieczka at sieczka.org
Tue Dec 15 12:24:59 EST 2009
M S pisze:
> Kubuntu 9.10 64bit, using GRASS 6.5.
> I ran v.breach on a stream network extracted with r.stream.extract.
> It runs through the program, and puts up an error dialogue at
> v.parallel. Attached is the log file. It looks like a negative
> number is being passed to v.parallel. I saw in the documentation this
> might be a problematic module in the script for non-metric coordinate
> system. Below is the portion of the output box from the module. Note
> the error 11 lines down.
> Building topology for vector map <breach_pt_segm_2l_r_tmp_5636_0_v_breach_sh>...
> Registering primitives...
> 100 primitives registered
> 259 vertices registered
> Building areas...
> 0 areas built
> 0 isles built
> Attaching islands...
> Attaching centroids...
> Number of nodes: 100
> ERROR: value <-0.00001> out of range for parameter <distance>
> Number of primitives: 100
> Number of points: 0
> Number of lines: 100
> Number of boundaries: 0
> Number of centroids: 0
> Legal range: 0-100000000
> Description:
> Creates parallel line to input vector lines.
> Keywords:
> vector, geometry
> Should I look in the script for this portion, and check if it is a
> metric issue? or does this seem like a different problem?
A different one. v.parallel used to accept negative offsets to
distinguish left/right. Now (after v.parallel2 replaced it) it doesn't
accept negative offsets anymore.
Maciek
> 2009/12/14 Maciej Sieczka <msieczka at sieczka.org>:
>> Luís Ferreira pisze:
>>> I used v.breach with both SQLite and dbf, with ETRS89 metric negative
>>> coordinates, from 20m to 2m resolution and worked fine.
>>> System: Ubuntu 9.10 Karmic Koala, 64 bits, GRASS 6.4SVN.
>>> But I remember to see some warnings like yours. Are these warnings
>>> critical? Visually, the interpolated DEMs with v.surf.rst are
>>> coherent.
>> I'll let you know next time I take a hobbyist look at v.breach. But I
>> really don't know when it will be.
>> Good luck.
>> Maciek
>>> On Mon, 2009-12-14 at 04:57 +0100, Maciej Sieczka wrote:
>>>> @Luís: I applied most your of patch. Thanks! Are you sure that's
>>>> all errors? I keep on getting warnings like:
>>>> WARNING: Unable to get point on line: cat = 1 offset = 2.831711
>>>> (line length = 0)
>>>> at v.segment calls in the script, and a crash at v.in.ascii.
>> Maciej Sieczka
>> http://www.sieczka.org
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Maciej Sieczka
