[GRASS-user] v.out.ascii output modification
    Maxime Phaneuf
    maxime.phaneuf at usherbrooke.ca
    Wed Dec 16 09:11:38 EST 2009
Hello everybody,
As the title says, I'm trying to use r.profile with the output of r.drain. I
know I cannot use directly the output, and instead I need to transform
r.drain to a vector line and transform it to a ascii point file
(v.out.ascii).
So, when the output form r.drain has been transformed to a ascii point file,
I cannot use it because there is a third column (the category) preventing me
from piping it into r.profile. I tried deleting the category but this
doesn't work.
I can always use awk to delete characters in the ascii file that I don't
need, but I was wondering if there is a quicker way to do it.
Basically what I need is to get from this ascii point file:
X   Y     CAT
xxx|yyy|1
xxx|yyy|1
to:
X    Y
xxx|yyy
without using a awk-like method.
Is it possible?
Thank you,
Maxime
View this message in context: http://n2.nabble.com/v-out-ascii-output-modification-tp4175638p4175638.html
Sent from the Grass - Users mailing list archive at Nabble.com.
