[GRASS-user] Calibrating colors of a series of maps
Glynn Clements
glynn at gclements.plus.com
Sat Dec 26 06:54:05 EST 2009
Jan Hartmann wrote:
> I am working with series of old topographical maps, rangnig from 10 to
> 600 map sheets per map. Each sheet is discolored a bit from age. How can
> I process a complete series in such a way that there are no differences
> visible any more between map sheets? Preferably I would like to
> downsample them to 8 bits color table, as the originals only have a
> small set of colors. In other words: how do I calibrate s set of maps to
> the same optimal color table?
This is probably better done with general image-processing software,
e.g. pnmquant (from the Netpbm package) or "convert -colors ..." (from
ImageMagick).
