[GRASS-user] Mask creation from sporadic data v.hull
Jed
jedfrechette at gmail.com
Fri Dec 18 23:54:00 EST 2009
JT-2 wrote:
> For a while now I have been trying to make an accurate mask for LiDAR
> points.
> As I am working with 1m resolution data I want the mask to be accurate (no
> more than 1m around the edge of the points/flight area).
Awhile ago, inorder to solve this same problem, I hacked together a little
script [1] that basically does a morphological closing on a raster map, e.g.
the output of r.in.xyz. My shell scripting is pretty weak and I keep meaning
to clean up the script and convert it to Python but it meets my needs for
the moment so I keep finding better ways to spend my time. Maybe it will be
of some help.
Best,
[1] http://bitbucket.org/jedfrechette/jdflib/src/tip/grass/r.closing
Jed Frechette
University of New Mexico Lidar Lab
www.unm.edu/~lidar
View this message in context: http://n2.nabble.com/Mask-creation-from-sporadic-data-v-hull-tp4186191p4190321.html
Sent from the Grass - Users mailing list archive at Nabble.com.
