[GRASS-user] grass70 and display monitor
Νίκος
Νίκος
Sun Dec 20 10:43:21 EST 2009
On Fri, 2009-12-18 at 08:53 -0700, Michael Barton wrote:
> On Dec 18, 2009, at 3:45 AM, grass-user-request at lists.osgeo.org wrote:
> > Date: Thu, 17 Dec 2009 23:21:18 +0100
> > From: ????? ?????????? <nikos.alexandris at felis.uni-freiburg.de>
> > Subject: Re: [GRASS-user] grass70 and display monitor
> > To: Glynn Clements <glynn at gclements.plus.com>
> > Cc: GRASS user list <grass-user at lists.osgeo.org>
> > Message-ID: <1261088478.7528.2.camel at vertical>
> > Content-Type: text/plain; charset="UTF-8"
> > On Thu, 2009-12-03 at 18:59 +0000, Glynn Clements wrote:
> >> Vincent Bain wrote:
> >>> May I be considered bothersome, but was it really impossible to achieve
> >>> (like in grass65) the development of a wxGUI (which I really enjoy too)
> >>> while keeping the complete set of "historical" command line
> >>> environment ?
> >> Very little is actually impossible, but the disadvantages (in terms of
> >> both effort and detriment to the end product) far outweigh the
> >> advantages.
> > I loved the "d.mon & co" tools ;-). But I understand that they had to be
> > dropped. Is there already something in the wiki (with respect to grass70
> > and interactive d.* tools)?
> > Thanks, Nikos
> Nikos,
> Rather than trying to have primitive interaction built in to different display modules, they all now work as true command line tools where you type a command with arguments and get a result. All d.* modules that worked as command line tools before (e.g., d.rast, d.vect) still work that way. See further explanations at <http://lists.osgeo.org/pipermail/grass-user/2009-December/053520.html>
> For d.* modules that had some kind of primitive GUI built into the module, they have either been switched to true command-line tools or are dropped from GRASS 7 until they are rewritten to that standard.
> Instead of trying to build interaction into each module, they all can now work with an independent GUI layer on top of the modules. This is what it is for. The current GUI will do all of the interaction of prior d.* modules with built-in GUI with the exception of a few modules (notably r.digit [super primitive and not really needed with vdigit and v.to.rast], i.class, and i.ortho.photo) and more.
> So you can do what you did before in a nicer environment.
Michael,
I did read (almost all of) your posts WRT to grass70 and d.*zzz.
However, I want to say that, honestly, I appreciate the time you invest
for clarifications (again).
It's one of those things that gives the community a meaning and
personally it makes me feel being a part of it.
Thank You, Nikos
