[GRASS-user] Gathering all layers, defining subset
Rich Shepard
rshepard at appl-ecosys.com
Mon Dec 21 18:20:49 EST 2009
On Mon, 21 Dec 2009, Hamish wrote:
> use v.proj, r.proj top move maps between different locations. use g.copy
> to copy among the same location but different mapsets, probably with
> @othermapset for the source map name's mapset. see also the g.mapsets
> module (with an "s")
> a location will have a specific projection setting, see 'g.proj -p'. If
> you know they are the same you can symlink the mapset from one location
> into another at your own risk.
Hamish,
Mea culpa! I read the man pages for g.copy and g.mapsets and saw that they
work only among mapsets in one location. I forgot that v.proj and r.proj are
needed to copy among locations, even when the projections are the same.
Thanks,
Rich
