[GRASS-user] r.proj: fixing a failure
Hamish
hamish_b at yahoo.com
Tue Dec 22 03:32:43 EST 2009
Maciej wrote:
> Set the output location's region to the extent of your to-be-reprojected
> data, before running r.proj in the input location.
tip:
v.proj'ing over a v.in.region box can help there. Then I usually try
to set the resolution to be a tiny bit better than the source rows x cols.
If there will bit a lot of rotation I try to set it even finer.
Hamish
