[GRASS-user] r.proj: fixing a failure
Rich Shepard
rshepard at appl-ecosys.com
Tue Dec 22 11:49:00 EST 2009
On Tue, 22 Dec 2009, Hamish wrote:
> Maciej wrote:
>> Set the output location's region to the extent of your to-be-reprojected
>> data, before running r.proj in the input location.
> tip:
> v.proj'ing over a v.in.region box can help there. Then I usually try
> to set the resolution to be a tiny bit better than the source rows x cols.
> If there will bit a lot of rotation I try to set it even finer.
Advice from either or both of you will help me quickly understand what
needs to be done so I can avoid future problems.
Here is the source (output?) location's WIND for the raster DEM:
proj: 99
zone: 0
north: 1735231.43724681
south: 1120657.1324816
east: 952979.22944945
west: 143667.18968253
cols: 24657
rows: 18724
e-w resol: 32.82281055
n-s resol: 32.82281055
top: 1
bottom: 0
cols3: 24657
rows3: 18724
depths: 1
e-w resol3: 32.82281055
n-s resol3: 32.82281055
t-b resol: 1
and here is the destination (input?) location's WIND for the state's area:
proj: 99
zone: 0
north: 1326000
south: 1278000
east: 817000
west: 766500
cols: 1538
rows: 1462
e-w resol: 32.83485046
n-s resol: 32.83173735
top: 1
bottom: 0
cols3: 50500
rows3: 48000
depths: 1
e-w resol3: 1
n-s resol3: 1
t-b resol: 1
This is based on running v.proj on 10 vector maps from their original
locations.
TIA,
Rich
