[GRASS-user] r.proj: fixing a failure
    Rich Shepard
    rshepard at appl-ecosys.com
    Tue Dec 22 11:54:37 EST 2009
On Tue, 22 Dec 2009, Hamish wrote:
> tip: v.proj'ing over a v.in.region box can help there. Then I usually try
> to set the resolution to be a tiny bit better than the source rows x cols.
> If there will bit a lot of rotation I try to set it even finer.
Hamish,
   I'm missing something important which is probably obvious to you and
others. The project location contains vector maps. My reading of the
v.in.region man page tells me its function is to "Create a new vector from
the current region." That suggests that the resulting output map is the same
as the displayed vector map but with a new name.
   If I then run v.proj on the display of the new map what have I changed?
More importantly, how does that help resolve my inability to run r.proj on a
DEM map and reproject it to the project's location?
   A clue stick would help.
Thanks,
Rich
