[GRASS-user] I: problems with v.edit
Martin Landa
landa.martin at gmail.com
Sun Feb 1 17:25:33 EST 2009
Ciao Chiara,
2009/1/27 chiaraercoli at tiscali.it <chiaraercoli at tiscali.it>:
>> I have a problem with v-edit.
>> I have to break a vector line
>> into two parts near a point. I gave this command:
>> v.edit map=ret_125
>> layer=1 type=line tool=break thresh=$ris_edit coords=$x,$y snap=no
>> where " $ris_edit " depends on the resolution of the DEM raster
> map,
>> "$x" and "$y" are the coordinates of the point.
> are you sure that threshold value is enough to select vector feature
> which you want to break?
> v.edit map=ret_125 tool=select thresh=$ris_edit coords=$x,$y
v.out.ascii punto_minimo
861020.54634226|7317237.09688885|1
v.edit ret_125 tool=select coord=861020.54634226,7317237.09688885 thresh=15 --q
1
OK, feature selected
v.edit ret_125 tool=break coord=861020.54634226,7317237.09688885
thresh=15 snap=no type=line layer=1
OK, feature broken
Check:
1,2
So where is the problem? ;-)
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
