[GRASS-user] problem setting region in 6.4 rc3
Nick Cahill
ndcahill at wisc.edu
Tue Feb 3 09:40:54 EST 2009
Hello,
Further on this. I tried creating a new location and mapset to see if
there were differences in the projection parameters or if something
was screwy. On startup, it gives an error I hadn't noticed before,
Warning: TclTk Aqua 8.4 unsupported
Here's the output:
'/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh'; exit
Last login: Tue Feb 3 08:11:27 on console
Nicks-Macbook:~ nick$ '/Applications/GRASS-6.4.app/Contents/MacOS/
grass.sh'; exit
Rebuilding Addon HTML manual pages index...
Rebuilding Addon menu...
Cleaning up temporary files ...
Starting GRASS ...
-- here I created the new location and mapset, UTM Zone 35, entering
the parameters by hand. After apparently successfullly creating the
new mapset, GRASS failed with
TkMacOSXDoHLEvent failed : cppe 1 ,kHighLevelEvent
61657674 0000 tvea,-1708
and the Wish Shell hung, unresponsive. Killed the process, and
restarted grass in the newly-created location and mapset; ran g.region
-p, and got the same error:
region for current mapset <projection field missing>
run "g.region"
Does anyone have any ideas what is wrong, or what I could do to
troubleshoot?
Many thanks,
Nick Cahill
On Feb 1, 2009, at 11:02 PM, Nick Cahill wrote:
> Hello,
> I'm using William Kyngesburye's OSX binaries of Grass 6.4 rc3, and
> find it doesn't work with my existing mapsets. On displaying a
> vector map, it gives an error "Error setting region: child process
> exited abnormally." If I set or display the region with g.region or
> g.region -p, I get the error "region for current mapset <projection
> field missing> xx run "g.region" The mapset is UTM zone 35, and
> works fine in 6.3. I installed the newest GDAL framework (1.6.0-5).
> I had thought the projection information was in one or more of the
> files in the mapset PROJ_INFO, etc., which are (for one typical
> mapset):
> DEFAULT_WIND:
> proj: 1
> zone: 35
> north: 1
> south: 0
> east: 1
> west: 0
> cols: 1
> rows: 1
> e-w resol: 1
> n-s resol: 1
> top: 1
> bottom: 0
> cols3: 1
> rows3: 1
> depths: 1
> e-w resol3: 1
> n-s resol3: 1
> t-b resol: 1
> PROJ_INFO:
> datum: wgs84
> towgs84: 0.000,0.000,0.000
> proj: utm
> ellps: wgs84
> a: 6378137.0000000000
> es: 0.0066943800
> f: 298.2572235630
> zone: 35
> PROJ_UNITS
> unit: meter
> units: meters
> meters: 1.0
> WIND
> proj: 1
> zone: 35
> north: 44865376.2790889
> south: 4026393.07584904
> east: 12546112.5351774
> west: -1477754.5340503
> cols: 184585
> rows: 442103
> e-w resol: 75.97511753
> n-s resol: 92.37436345
> top: 1759.33
> bottom: 0
> cols3: 184585
> rows3: 442103
> depths: 1759
> e-w resol3: 75.97511753
> n-s resol3: 92.37436345
> t-b resol: 1.00018487'
> I'm not sure why the default window sets it to one row and one
> column, but it works OK in 6.3. Any idea what's wrong here?
> Many thanks,
> Nick Cahill
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
