[GRASS-user] v.in.ascii
Dylan Beaudette
debeaudette at ucdavis.edu
Tue Feb 3 16:04:22 EST 2009
On Tuesday 03 February 2009, Harald Hofmann wrote:
> Hello all,
> I have been using GRASS now for a couple of years but I am new to the
> mailing list.
> Nevertheless, I could still not solve one problem to a satisfactory extend.
> What I mean is the header import in v.in.ascii.
> I have point data with chemical analysis in the attribute table. Every
> time I import a text file, containing these tables and using v.in.ascii,
> the header is not imported, which is quit annoying when you have 20 or
> 30 different parameters.
> I have solved it in a, some kind of clunky, way. After importing the
> text file, I open the dbf in OOCalc and replace the first line with the
> header that I copy from the original text file.
> I was just wondering if there isn't an easier, more elegant method to do
> so.
> Thanks
> Harald
Which version of GRASS?
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
