[GRASS-user] ERROR geonames_features
Markus Neteler neteler at osgeo.org
Tue Feb 17 18:28:07 EST 2009
On Sun, Feb 15, 2009 at 8:13 PM, Zahid Parvez
<grassgisbangladesh at gmail.com> wrote:
> Dear grass user,
> It may be a silly error but it is confusing me. I will be very glad if you
> could help.
> I am learning GRASS GIS from "Open source gis a grass gis approach" book.
> This a an excellent book for the beginners.
> I am using winGRASS 6.3.0.4  native version and running nc_spm 08 at PERMANENT.
> I have executed the following comand:
> r.contour elevation out=elev_contour_1111m step=3 min=55 max=154
> it is giving following error:
> BMI-DBF driver error:
> SQL parser error: syntax error, unexpected NAME, expecting '(' processing
> 'geonames_features'
> in statement:
> create table database geonames_features.elev_contour_1111m ( cat integer,
> level double precision )
> Error in db_execute_immediate()
> Unable to create table: create table database
> geonames_features.elev_contour_1111m ( cat integer, level double precision )
>  then I have run the following steps:
>  -> db.connect
>  -> db.connect driver=dbf
> {database=$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/} {schema=database
> geonames_features}
>  -> I want to remove the schema=database geonames_features ; because i think
> it is creating problem
>  -> I have deleted from txtbox and execute " db.connect driver=dbf
> {database=$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/} "
>  -> but when again I open db.connect window it shows schema=database
> geonames_features
>  -> How can I remove it.
The easiest way is to go into the PERMANENT directory and
exit the VAR file and remove the offending schema line using
Wordpad or another ASCII editor.
DBF does not support schema.
Hope this helps,
Markus
