[GRASS-user] library problem with i.landsat.toar
Christine Sandmeier christine.sandmeier at gmx.de
Wed Feb 18 19:32:31 EST 2009
-------- Original-Nachricht --------
> Datum: Wed, 18 Feb 2009 16:01:29 -0800 (PST)
> Von: Hamish <hamish_b at yahoo.com>
> An: grass-user at lists.osgeo.org, Christine Sandmeier <christine.sandmeier at gmx.de>
> Betreff: Re: [GRASS-user] library problem with i.landsat.toar
> Christine Sandmeier wrote:
> > I wanted to install the i.landsat.toar - addon, following
> > the instruction in the README-file (make
> > MODULE_TOPDIR=$HOME/grass64/),
> > I also made "./configure" before and also
> was grass already built, or are you adding to a packaged binary version?
grass was already built before.
> > "make lib", which says "Nothing to do for
> > target »lib«"!
> that should be "make libs" not "make lib"
I tried it with "make libs", instead of "make lib", but this doesn't help (maybe this should be changed in the README-file of the grass-addons).
> > but when I try to start the i.landsat.toar addon, it says
> > "Incompatible library version for module".
> > I recompiled grass, but this didn't help.
> you might have to remove any other version of grass to keep it from
> getting confused (generally this isn't needed, but may help if the
> local system has gotten mixed up).
I already removed all other versions of grass - this didn't help.
> another way if you fully build grass from source is to copy the
> i.landsat.toar/ directory into the imagery/ dir in the main grass source
> code, and after grass has built cd imagery/i.landsat.toar/ and run "make"
> with no arguments.
I also tried this before and did it again now. This works fine for other addons, but didn't help for i.landsat.toar.
any other ideas?
Jetzt 1 Monat kostenlos! GMX FreeDSL - Telefonanschluss + DSL
für nur 17,95 Euro/mtl.!* http://dsl.gmx.de/?ac=OM.AD.PD003K11308T4569a
