[GRASS-user] GRASS 7 and SQLITE o POSTGRES
Gabriele N.
gis.gn at libero.it
Sat Feb 21 06:44:05 EST 2009
Hi Benjamin, thanks for the reply.
I read something about spatial lite.
I work mainly with GRASS and thought to use it with SQLite because GRASS 7
should be able to work directly on the SQLite for the geometries and the
attributes (in short, without v.exeternal).
I think, but I do not know if it is correct, that implementing a DB in
SQLite might be possible to access data with GRASS 7, QGIS, gvSIG, etc...
(my colleagues still do not use GRASS) .... but maybe it's only my hope :-)
With postgres/postgis I should always connect with v.external and I could
not do spatial analysis using the tools of GRASS ... right?
Thank you very much
Gabriele
Benjamin Ducke wrote:
> Hi Gabriele,
> A spatial database extension allows you to store
> geographic features as part of the database itself.
> There are many advantages to this, especially if you
> work with huge vector datasets.
> SQLite has a spatial extension equivalent to PostGIS.
> It is called SpatiaLite. It has the same functionality
> as PostGIS. The latest version of OGR already has some
> basic support for SQLite, so hopefully in the near future
> all open source GIS will support SQLite/SpatiaLite as
> a datasource.
> However, if you are planning to to set up a spatial data
> infrastructure for collaborative work, you should probably
> choose PostgreSQL/PostGIS as your data backend, because
> it supports user access control and is currently better
> supported by open source GIS.
> Ben
> ----- Original Message -----
> From: "Gabriele N." <gis.gn a libero.it>
> To: grass-user a lists.osgeo.org
> Sent: Friday, February 20, 2009 5:38:48 PM GMT +00:00 GMT Britain,
> Ireland, Portugal
> Subject: [GRASS-user] GRASS 7 and SQLITE o POSTGRES
> Hello.
> I work with colleagues sharing the files (shapes .. etc) that are on a NAS
> server.
> I use ubuntu 8.10 (with GRASS locally) and my colleagues use windows.
> I would do this:
> - A GIS with all these data
> - Building a database (sqlite or postgres/postgis/ on NAS)
> - An excellent organization of the data
> - To enable access to data with other software (such as QGIS and gvSIG)
> GRASS 7 will default SQLite and therefore should be different to GRASS 6.
> In
> the sense that now GRASS 6 connects to the DB (postgres and / or sqlite)
> but
> works differently than the dbf ... or wrong?
> SQLite does not have the spatial component as postgis with postgres? What
> does this?
> Can you tell me the steps to follow?
> What do you recommend?
> Thanks
> Gabriele
> http://n2.nabble.com/GRASS-7-and-SQLITE-o-POSTGRES-tp2360247p2360247.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
> Files attached to this email may be in ISO 26300 format (OASIS Open
> Document Format). If you have difficulty opening them, please visit
> http://iso26300.info for more information.
View this message in context: http://n2.nabble.com/GRASS-7-and-SQLITE-o-POSTGRES-tp2360247p2363407.html
