[GRASS-user] GRASS 7 and SQLITE o POSTGRES
    Moritz Lennert
    mlennert at club.worldonline.be
    Sat Feb 21 07:42:35 EST 2009
On 21/02/09 12:44, Gabriele N. wrote:
> Hi Benjamin, thanks for the reply.
> I read something about spatial lite.
> I work mainly with GRASS and thought to use it with SQLite because GRASS 7
> should be able to work directly on the SQLite for the geometries and the
> attributes (in short, without v.exeternal).
> I think, but I do not know if it is correct, that implementing a DB in
> SQLite might be possible to access data with GRASS 7, QGIS, gvSIG, etc...
> (my colleagues still do not use GRASS) .... but maybe it's only my  hope :-)
The SQLite support in GRASS concerns the attribute management, not
geometries. To access geometries in a SpatiaLite, you have to go through
v.external.
One of the main reasons is that GRASS vector format is topological and
SpatiaLite isn't. Most vector modules expect topological structure to work.
> With postgres/postgis I should always connect with v.external and I could
> not do spatial analysis using the tools of GRASS ... right?
Right, but it is the same for SpatiaLite.
Note that QGIS can access GRASS data directly (not sure about gvSIG) so
you can actually have your geometries in GRASS format and still work
with QGIS.
Moritz
> Thank you very much
> Gabriele
> Benjamin Ducke wrote:
>> Hi Gabriele,
>> A spatial database extension allows you to store
>> geographic features as part of the database itself.
>> There are many advantages to this, especially if you
>> work with huge vector datasets.
>> SQLite has a spatial extension equivalent to PostGIS.
>> It is called SpatiaLite. It has the same functionality
>> as PostGIS. The latest version of OGR already has some
>> basic support for SQLite, so hopefully in the near future
>> all open source GIS will support SQLite/SpatiaLite as
>> a datasource.
>> However, if you are planning to to set up a spatial data
>> infrastructure for collaborative work, you should probably
>> choose PostgreSQL/PostGIS as your data backend, because
>> it supports user access control and is currently better
>> supported by open source GIS.
>> Ben
>> ----- Original Message -----
>> From: "Gabriele N." <gis.gn at libero.it>
>> To: grass-user at lists.osgeo.org
>> Sent: Friday, February 20, 2009 5:38:48 PM GMT +00:00 GMT Britain,
>> Ireland, Portugal
>> Subject: [GRASS-user] GRASS 7 and SQLITE o POSTGRES
>> Hello.
>> I work with colleagues sharing the files (shapes .. etc) that are on a NAS
>> server.
>> I use ubuntu 8.10 (with GRASS locally) and my colleagues use windows.
>> I would do this:
>> - A GIS with all these data
>> - Building a database (sqlite or postgres/postgis/ on NAS)
>> - An excellent organization of the data
>> - To enable access to data with other software (such as QGIS and gvSIG)
>> GRASS 7 will default SQLite and therefore should be different to GRASS 6.
>> In
>> the sense that now GRASS 6 connects to the DB (postgres and / or sqlite)
>> but
>> works differently than the dbf ... or wrong?
>> SQLite does not have the spatial component as postgis with postgres? What
>> does this?
>> Can you tell me the steps to follow?
>> What do you recommend?
>> Thanks
>> Gabriele
>> View this message in context:
>> http://n2.nabble.com/GRASS-7-and-SQLITE-o-POSTGRES-tp2360247p2360247.html
>> Sent from the Grass - Users mailing list archive at Nabble.com.
>> grass-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> Files attached to this email may be in ISO 26300 format (OASIS Open
>> Document Format). If you have difficulty opening them, please visit
>> http://iso26300.info for more information.
