[GRASS-user] error with v.net.salesman
José María Michia
jose.maria.michia at gmail.com
Thu Jan 1 18:28:46 EST 2009
> Perhaps that solves the problem.
> Additionally, d.vect can show node numbers with
> disp=topo
> This should, in combination with d.zoom help to identify the
> (I suppose) data problem.
> Markus
Thanks. Using this advice, I've found the problem: a road isolated
from the rest.
Other command that I've used to debug my data:
v.build map=myroads_net option=dump --verbose |less
The above command show all nodes with full info (the coordinates
showing here can facilitate zooming to node).
I deleted the road isolated, and tried again with success!
Thank you very much.
Saludos
José María
