[GRASS-user] Move vertex in v.digit releasebranch
    Luca Casagrande
    thedoktor78 at gmail.com
    Fri Jan  2 12:09:44 EST 2009
Hi Martin,
Martin Landa wrote:
> Hi,
> 2008/12/21 Casagrande Luca <thedoktor78 at gmail.com>:
>> Hello everybody!
>> I am testing the releasebranch with the wxpython interface and I found
>> this
>> little problem:
>> - open roads from spearfish and start edit it
>> - select the move vertex tool
>> - after you select a vertex with the left click, if the button is pressed
>> again by mistake, the display freeze.
> should be fixed in r35035 (relbr64).
Thanks, it's fine now.
I'll keep testing..
Luca
View this message in context: http://n2.nabble.com/Move-vertex-in-v.digit-releasebranch-tp1886429p2102368.html
Sent from the Grass - Users mailing list archive at Nabble.com.
