[GRASS-user] Help with reprojection
Alex Bernstein
pofig37 at gmail.com
Fri Jan 2 14:04:44 EST 2009
I'm new to GRASS, and am having trouble with reprojection. I've spent
two days trying to figure this out, and I feel that I'm close, but
reprojection is still failing. Could anyone clue me in what I'm
missing?
The input data set is Natural Earth II map of the world
<http://www.nacis.org/data/NE2/NE2_WDB1.jpg> 16200x8100 JPG in plate
carrée projection. I need to reproject it into Lambert azimuthal
equal-area projection centered on N0 E15. I'm using WinGRASS 6.3.0.
First, I've created GRASS location "geographic" with following region
and projection:
> g.region -p
projection: 99 (Equidistant Cylindrical (Plate Caree))
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 8100
south: 0
west: 0
east: 16200
nsres: 1
ewres: 1
rows: 8100
cols: 16200
cells: 131220000
> g.proj -p datumtrans=0
PROJ_INFO-------------------------------------------------
name : Equidistant Cylindrical (Plate Caree)
datum : wgs84
towgs84 : 0.000,0.000,0.000
proj : eqc
ellps : wgs84
a : 6378137.0000000000
es : 0.0066943800
f : 298.2572235630
lat_0 : 0.0000000000
lat_ts : 0.0000000000
lon_0 : 0.0000000000
-PROJ_UNITS------------------------------------------------
unit : meter
units : meters
meters : 1.0
I then imported the JPG map, which got split into color channels and
composed the channels together into single map.
After, I created a new location "lambert":
> g.region -p
projection: 99 (Lambert Azimuthal Equal Area)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 8100
south: 0
west: 0
east: 16200
nsres: 1
ewres: 1
rows: 8100
cols: 16200
cells: 131220000
-PROJ_INFO-------------------------------------------------
name : Lambert Azimuthal Equal Area
datum : wgs84
proj : laea
ellps : wgs84
es : 0.0066943800
f : 298.2572235630
lon_0 : 15.0000000000
x_0 : 0.0000000000
y_0 : 0.0000000000
unit : meter
units : meters
meters : 1.0
Finally, when I try reprojection I get "Input raster map is outside
current region" error:
> r.proj input=NE2 location=geographic mapset=PERMANENT method=cubic
Input Projection Parameters: +proj=eqc +lat_0=0.0000000000
+lat_ts=0.0000000000 +lon_0=0.0000000000 +a=6378137 +rf=298.257223563
+no_defs +towgs84=0.000,0.000,0.000
Input Unit Factor: 1
Output Projection Parameters: +proj=laea +lat_0=0.0000000000
+lon_0=15.0000000000 +x_0=0.0000000000 +y_0=0.0000000000 +a=6378137
+rf=298.257223563 +no_defs +towgs84=0.000,0.000,0.000
Output Unit Factor: 1
Input raster map is outside current region
How can I make this work?
Thanks,
Alex
