[GRASS-user] v.in.dxf lines with no elevation
Adam Dershowitz
adershowitz at exponent.com
Mon Jan 5 21:02:54 EST 2009
I have a dxf file that contains both lines and points. If I import it
into grass with v.in.dxf the lines end up at an elevation of 0, while
the points show up correctly. I have verified that the lines do in
fact have an elevation by importing the dxf both into google sketch up
and blender as a test.
I googled around some and it seems like it used to be necessary to run
v.in.dxf3d but I can't find that, and it appears that it was just
incorporated into v.in.dxf, best I can tell.
Any suggestions for getting the lines to the correct elevation?
Thanks,
--Adam
