[GRASS-user] grass' build problem with libtoolize
MORREALE Jean Roc
jr.morreale at enoreth.net
Tue Jan 6 16:42:07 EST 2009
Markus Neteler wrote:
> Found a workaround: replace
> %configure
> with
> ./configure
> and libtoolize is no longer used.
> Two fixes are necessary, then it compiles (running here now).
> I'll send you the SPEC file.
> Markus
Thank you for the tips !
>Older version yes, but with updates to 2009.x
yes but actually in cooker you can't even install it because of a
dependency's conflict so a new grass rpm is really needed here.
Thanks again
