[GRASS-user] grass' build problem with libtoolize
Markus Neteler neteler at osgeo.org
Tue Jan 6 01:38:12 EST 2009
On Mon, Jan 5, 2009 at 11:00 PM, MORREALE Jean Roc
<jr.morreale at enoreth.net> wrote:
> Hi,
> I'm trying to build grass 6.4 rc1 from sources (using the tarball available)
> but I get this blocking error :
> "libtoolize: cannot handle variables in AC_CONFIG_AUX_DIR"
Please post the configure parameters/flags for inspection.
> Here is the complete log ->
> http://pastebin.mandriva.com/5505
> I've searched but the only part I've been able to understand so far is that
> it is somewhat linked to the configure file so there is the options I used :
> --with-dbm-includes=%{_includedir}/gdbm/
> --with-postgres-includes='%{_includedir}/postgresql
> %{_includedir}/postgresql/internal' --with-freetype
> --with-freetype-includes=%{_includedir}/freetype2 --with-motif
> --with-opengl-libs=%{_prefix}/X11R6/%{_lib}
> --with-motif-includes=%{_prefix}/X11R6/include --with-gdal --with-odbc
> --enable-largefile --with-ffmpeg
> --with-curses --with-python --with-sqlite \
> --with-cxx --with-proj-share=%{_datadir}/proj \
> --with-nls --with-wxwidgets=%{_libdir}/wxPython/bin/wx-config
Apparently you are trying to create a RPM file? Please point
us to the SPEC file (note that the tarball contains
rpm/mandriva/grass*.spec
See also
http://svn.mandriva.com/cgi-bin/viewvc.cgi/packages/cooker/grass/current/
> I'm using mandriva cooker/libtool 1.5.26/gcc 4.3.2
I am using Mandriva 2009.0 and have no problems.
But libtool isn't used/usable for GRASS, probably that's the
source of the problem. We need to know more specifically
what you plan to do.
Best
Markus
