[GRASS-user] v.clean process killed itselt!?
Markus Neteler
neteler at osgeo.org
Fri Jan 9 16:17:20 EST 2009
On Fri, Jan 9, 2009 at 10:07 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Nikos Alexandris wrote:
>> > > How should on go about and clean this map?
>> > On a 64-bit system with a lot of RAM. A 32-bit system limits each
>> > process to a 4GiB address space, some of which is reserved.
>> My system is 64-bit, CoreDuo 2,53GHz, and I run Ubuntu Intrepid 64-bit.
>> Unfortunately I can't install more RAM.
>> Will more swap space help?
> I doubt it.
I wonder if we have a memory leak in the vector library.
Compare
http://trac.osgeo.org/grass/ticket/14
If it is there bit small normal usage won't trigger it in a significant
way. But this huge map would do.
Markus
