[GRASS-user] Display thematic vector map - WinGRASS 6.3 (Vista)
Michael Barton
michael.barton at asu.edu
Thu Jan 15 11:46:52 EST 2009
Probably the d.vector.thematic script can be copied from 6.4 and run
in 6.3 with little or no modification.
Michael
______________________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
On Jan 15, 2009, at 3:27 AM, Moritz Lennert wrote:
> On 15/01/09 05:22, Michael Barton wrote:
>> I'm pretty sure that this is a Vista issue, though one that has
>> been solved in 6.4.
> And as the OP is using 6.3, he doesn't have access to that solution,
> yet. So, we'll have to wait for the version of WinGRASS to decide
> whether there might be additional issues in Vista.
> Moritz
>> Michael
>> On Jan 14, 2009, at 7:33 PM, Matt wrote:
>>> Ken,
>>> You are not alone. I tried the thematic vector example on page
>>> 171 of
>>> Neteler & Mitasova and also encountered the "You must open a display
>>> monitor" message. I'm running 6.3.0-4 on Vista.
>>> Matt
>>> On Tue, Jan 6, 2009 at 12:51 PM, Moritz Lennert
>>> <mlennert at club.worldonline.be> wrote:
>>>> On 06/01/09 17:51, Michael Barton wrote:
>>>>> Thanks for the correction. WinGRASS supports PNG output, not a
>>>>> monitor.
>>>>> d.vect.thematic was rewritten to use direct rendering through
>>>>> PNG, so it
>>>>> should work on Windows.
>>>> This was done in 6.4, so it is not available in winGRASS, yet,
>>>> which is
>>>> based on 6.3. Just replacing the script doesn't work, either as
>>>> it use the
>>>> fs= parameter of v.db.connect which wasn't introduced until 6.4.
>>>> So, another strident call for the a 6.4 winGRASS.
>>>> Moritz
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
