[GRASS-user] Display thematic vector map - WinGRASS 6.3 (Vista)
Moritz Lennert
mlennert at club.worldonline.be
Sun Jan 18 05:55:52 EST 2009
On 15/01/09 17:46, Michael Barton wrote:
> Probably the d.vector.thematic script can be copied from 6.4 and run in
> 6.3 with little or no modification.
As mentioned in the last mail below, you cannot copy it without
modifications, as v.db.connect's fs= parameter was introduced in 6.4,
and I'm not sure that's the only change.
I think the easiest would probably be to copy the lines setting the
relevant environment variables from 6.4 to 6.3 to replace the d.mon call.
Moritz
> Michael
> ______________________________
> C. Michael Barton, Professor of Anthropology
> Director of Graduate Studies
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> voice: 480-965-6262; fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> On Jan 15, 2009, at 3:27 AM, Moritz Lennert wrote:
>> On 15/01/09 05:22, Michael Barton wrote:
>>> I'm pretty sure that this is a Vista issue, though one that has been
>>> solved in 6.4.
>> And as the OP is using 6.3, he doesn't have access to that solution,
>> yet. So, we'll have to wait for the version of WinGRASS to decide
>> whether there might be additional issues in Vista.
>> Moritz
>>> Michael
>>> On Jan 14, 2009, at 7:33 PM, Matt wrote:
>>>> Ken,
>>>> You are not alone. I tried the thematic vector example on page 171 of
>>>> Neteler & Mitasova and also encountered the "You must open a display
>>>> monitor" message. I'm running 6.3.0-4 on Vista.
>>>> Matt
>>>> On Tue, Jan 6, 2009 at 12:51 PM, Moritz Lennert
>>>> <mlennert at club.worldonline.be> wrote:
>>>>> On 06/01/09 17:51, Michael Barton wrote:
>>>>>> Thanks for the correction. WinGRASS supports PNG output, not a
>>>>>> monitor.
>>>>>> d.vect.thematic was rewritten to use direct rendering through PNG,
>>>>>> so it
>>>>>> should work on Windows.
>>>>> This was done in 6.4, so it is not available in winGRASS, yet,
>>>>> which is
>>>>> based on 6.3. Just replacing the script doesn't work, either as it
>>>>> use the
>>>>> fs= parameter of v.db.connect which wasn't introduced until 6.4.
>>>>> So, another strident call for the a 6.4 winGRASS.
>>>>> Moritz
>>>>> _______________________________________________
>>>>> grass-user mailing list
>>>>> grass-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
