[GRASS-user] GRASS and reading mapsets on NTFS
Patrick Giraudoux patrick.giraudoux at univ-fcomte.fr
Fri Jan 16 13:13:31 EST 2009
Dear listers,
I have just migrated from a computer double boot (Windows/Ubuntu Hardy)
with user data on a FAT32 partition to a new one with a NTFS partition
instead. All went OK except that I can read mapsets only when grass
(6.3) is started with sudo. If not, I can access locations in the
grassdata folder but maptsets are not read. Googling a bit within the
list I understand that grass can read only with owner rights (and not
only read/write permission) and this explains the difference. I agree
with comments that this it looks like a bit over the  top regarding
security (I may be wrong...).
Of course a solution would be to alvays work as "super user" (sudo) with
grass on the NTFS partition, but this is obviously not safe and not in
the spirit of Linux... On the other hand, I cannot move the data on the
ext3 partition since it was not designated for that (space is limited)
and more importantly I suppose this would make problem to read from
Windows (e.g. from QGIS under windows - teaching purpose)....
I would really like to use the NTFS partition to get the data shared by
the two systems.
As anyone an idea about a workaround ?
Patrick
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20090116/f81d1cc9/patrick_giraudoux.vcf
