[GRASS-user] db.select limitation + psql workaround
"Peter Löwe"
peter.loewe at gmx.de
Sun Jan 18 10:54:43 EST 2009
Thanks for your work, Markus !
Peter
-------- Original-Nachricht --------
> Datum: Sun, 18 Jan 2009 07:23:56 +0100
> Von: Markus Neteler <neteler at osgeo.org>
> An: Glynn Clements <glynn at gclements.plus.com>
> CC: GRASS user list <grass-user at lists.osgeo.org>, "Peter Löwe" <peter.loewe at gmx.de>
> Betreff: Re: [GRASS-user] db.select limitation + psql workaround
> On Sat, Jan 17, 2009 at 8:27 PM, Glynn Clements
> <glynn at gclements.plus.com> wrote:
> > Markus Neteler wrote:
> >> >> I do agree. However, since the statement begins with the
> >> >> "SELECT"-string, db.execute refuses to execute it.
> >> > This is a bug in db.execute, and the only simple fix is to remove the
> >> > check altogether.
> >> As simple as this?
> > Yes.
> Done in 7.trunk, devel6 and 6.4.0svn.
> Markus
Dr. Peter Löwe
Sensationsangebot verlängert: GMX FreeDSL - Telefonanschluss + DSL
für nur 16,37 Euro/mtl.!* http://dsl.gmx.de/?ac=OM.AD.PD003K1308T4569a
