[GRASS-user] db.select limitation + psql workaround
Markus Neteler neteler at osgeo.org
Sun Jan 18 01:23:56 EST 2009
On Sat, Jan 17, 2009 at 8:27 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> >> I do agree. However, since the statement begins with the
>> >> "SELECT"-string, db.execute refuses to execute it.
>> > This is a bug in db.execute, and the only simple fix is to remove the
>> > check altogether.
>> As simple as this?
> Yes.
Done in 7.trunk, devel6 and 6.4.0svn.
Markus
