[GRASS-user] db.select limitation + psql workaround
Sat Jan 17 14:27:44 EST 2009
Markus Neteler wrote:
> >> I do agree. However, since the statement begins with the
> >> "SELECT"-string, db.execute refuses to execute it.
> > This is a bug in db.execute, and the only simple fix is to remove the
> > check altogether.
> As simple as this?
Yes.
