[GRASS-user] Grass crashes when importing shapefile
Hamish hamish_b at yahoo.com
Fri Jan 16 21:10:55 EST 2009
Joshua Fletcher wrote:
> I'm new to Grass and still learning the ropes, but am
> having problems with grass "unexpectedly quitting"
could you expand on that? does a system error window pop up?
> while importing shapefiles.  I'm running leopard on a
> 2.33mhz 2GB Macbook Pro.  Shapefiles are in good shape,
> workable in both qgis and ArcGIS 9.3.  Several attempts with
> several different shapefiles all give same result.  I have
> been able to import only one shapefile successfully.  Any
> tips?
perhaps it is running out of memory? (I'm not sure how OSX deals with
that)  if so, try the v.in.ogr -t flag.
is the shapefile huge? does a small one work?
Hamish
