[GRASS-user] generating lines from points
Martin Landa landa.martin at gmail.com
Sun Jan 18 11:21:11 EST 2009
Hi all,
is there any simple way how to connect selected points?
E.g. to create line starting from point with category '1' to point
with category '2'.
If not, do you consider useful something like
v.edit map tool=addline cats=1,2 layer=1
or create multiple lines
v.edit map tool=addline cats=1,2,3,4 layer=1 # line from 1 to 2 and
line from 3 to 4
Anyway, v.edit doesn't not seem to be a good module for such functionality. (?)
Sure you can always write a simple script and use v.in.ascii approach
(can be quite slow).
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
