[GRASS-user] Original location: Hot to create from the command line ?
Moritz Lennert mlennert at club.worldonline.be
Mon Jan 19 06:04:26 EST 2009
On 19/01/09 10:47, peter.loewe at gmx.de wrote:
> Hi,
> is there an (easy) recipe to create a completely new location from
> scratch without using a GUI ?
> To be precise: If GRASS is started for the first time in "-text" mode
> (=no GUI) ** without having a sample location like Spearfish or North
> Carolina around**, how can location parameters (projection, extent,
> EPSG...) be handed over to set up a very first location ?
Just type in the name of the location you want to create and GRASS will
prompt you for the parameters.
Moritz
