[GRASS-user] Original location: Hot to create from the command
line ?
"Peter Löwe"
peter.loewe at gmx.de
Mon Jan 19 06:06:56 EST 2009
> > is there an (easy) recipe to create a completely new location from
> > scratch without using a GUI ?
> > To be precise: If GRASS is started for the first time in "-text" mode
> > (=no GUI) ** without having a sample location like Spearfish or North
> > Carolina around**, how can location parameters (projection, extent,
> > EPSG...) be handed over to set up a very first location ?
> Just type in the name of the location you want to create and GRASS will
> prompt you for the parameters.
> Moritz
That's true. But is there also a way to provide the parameters _without_ interaction with the user (-> GRASS scripting & automation) ?
Peter
Dr. Peter Löwe
<peter.loewe at gmx.de>
Sensationsangebot verlängert: GMX FreeDSL - Telefonanschluss + DSL
für nur 16,37 Euro/mtl.!* http://dsl.gmx.de/?ac=OM.AD.PD003K1308T4569a
