[GRASS-user] To change DEM resolution
Edmondo Elisei
edmondo.elisei at gmail.com
Mon Jan 19 09:20:48 EST 2009
I've a DEM with 90m m res. (from CGIAR SRTM) and I need drape over it a map
tif (resolution 1m).
Seeing the resultant map in NViz the quality is very low. I suppose it
depends from the different resolutions.
There is a way to change the DEM resolution?
Thanks
Regards
Edmondo
Un allegato HTML ? stato rimosso...
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090119/f7d83918/attachment.html
