[GRASS-user] To change DEM resolution
Dylan Beaudette debeaudette at ucdavis.edu
Mon Jan 19 10:39:56 EST 2009
On Monday 19 January 2009, Edmondo Elisei wrote:
> I've a DEM with 90m m res. (from CGIAR SRTM) and I need drape over it a map
> tif (resolution 1m).
> Seeing the resultant map in NViz the quality is very low. I suppose it
> depends from the different resolutions.
> There is a way to change the DEM resolution?
> Thanks
> Regards
> Edmondo
if you are using GRASS64, check out r.resamp.interp, otherwise r.bilinear
should do the trick.
Cheers,
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
