[GRASS-user] DBMI-DBF driver error
Markus Neteler
neteler at osgeo.org
Mon Jan 19 16:49:35 EST 2009
Matt,
On Sat, Jan 17, 2009 at 7:21 PM, Matt <mlpublic42 at gmail.com> wrote:
> I have a problem working through the DBF driver example on pp 174-175
> of Neteler & Mitasova with the North Carolina dataset. I''m running
> version 6.3.0-4 under Windows Vista. The first two commands execute
> without any obvious errors when run from the bottom window of "GIS.m".
> But the third command has problems.
> db.connect driver=dbf database='$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/'
> db.connect -p
> g.copy vect=roadsmajor,myroadsmajor
> Output from db.connect -p is
> river:dbf
("river" this is just a typo, no?)
> database:'$GISDBASE/$LOCATION_NAME/$MAPSET/dbf
> schema:
> group:
> Output from g.copy vect=roadsmajor,myroadsmajor is
> Copy vector <roadsmajor at PERMANENT> to current mapset as <myroadsmajor>
> DBMI-DBF driver error:
> Cannot create dbf database:
> 'C:/Users/Matt/Documents/GISdata/nc_spm_08/PERMANENT/dbf
Does the directory exist?
If no, can you create it manually?
Markus
> Cannot open database
> ''C:/Users/Matt/Documents/GISdata/nc_spm_08/PERMANENT/dbf'
> no database is open
> Unable to copy table <myroadsmajor>
> Cannot copy <roadsmajor at PERMANENT> to current mapset as <myroadsmajor>
> I've checked and the file
> 'C:/Users/Matt/Documents/GISdata/nc_spm_08/PERMANENT/roadsmajor.dbf'
> does indeed exist. What am I doing wrong?
> Thanks in advance.
> Matt
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
