[GRASS-user] DBMI-DBF driver error
    Matt
    mlpublic42 at gmail.com
    Mon Jan 19 19:17:51 EST 2009
You are correct.  'river.dbf' is a typo.  I did a cut and past, but
the first character of the first line in the "Output - GIS.m" window
always appears a couple of line up and to the right of the printer and
"X" icons: it should have read "driver:dbf".
The directory  'C:/Users/Matt/Documents/GISdata/nc_spm_08/PERMANENT/dbf'
does exist.
This is probably grasping as straws, but could the difference between
forward slash and back slash be important?  If I open a Windows
Command Prompt window (a DOS window) and type
     cd C:/Users/Matt/Documents/GISdata/nc_spm_08/PERMANENT/dbf
I go to the correct directory.  If I then type dir in the Command
Prompt window, I see the directory listing.
BUT  if I am back at the root directory (c:\) and type
     dir C:/Users/Matt/Documents/GISdata/nc_spm_08/PERMANENT/dbf
I get an error message.  Repeating with the back slash gives the
correct result in both cases.  For shorter examples "dir c:\" works,
but "dir c:/" does not work (invalid switch).  Depending how GRASS and
Windows interact, might this be a problem?
On Mon, Jan 19, 2009 at 4:49 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Matt,
> On Sat, Jan 17, 2009 at 7:21 PM, Matt <mlpublic42 at gmail.com> wrote:
>> I have a problem working through the DBF driver example on pp 174-175
>> of Neteler & Mitasova with the North Carolina dataset.  I''m running
>> version 6.3.0-4 under Windows Vista.  The first two commands execute
>> without any obvious errors when run from the bottom window of "GIS.m".
>>  But the third command has problems.
>> db.connect driver=dbf database='$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/'
>> db.connect -p
>> g.copy vect=roadsmajor,myroadsmajor
>> Output from db.connect -p is
>>     river:dbf
> ("river" this is just a typo, no?)
>>     database:'$GISDBASE/$LOCATION_NAME/$MAPSET/dbf
>>     schema:
>>     group:
>> Output from g.copy vect=roadsmajor,myroadsmajor is
>>     Copy vector <roadsmajor at PERMANENT> to current mapset as <myroadsmajor>
>>     DBMI-DBF driver error:
>>     Cannot create dbf database:
> Does the directory exist?
> If no, can you create it manually?
> Markus
>>     Cannot open database
>> ''C:/Users/Matt/Documents/GISdata/nc_spm_08/PERMANENT/dbf'
>>     no database is open
>>     Unable to copy table <myroadsmajor>
>>     Cannot copy <roadsmajor at PERMANENT> to current mapset as <myroadsmajor>
>> I've checked and the file
>> 'C:/Users/Matt/Documents/GISdata/nc_spm_08/PERMANENT/roadsmajor.dbf'
>> does indeed exist.  What am I doing wrong?
>> Thanks in advance.
>> Matt
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
