[GRASS-user] Aspect direction in r.slope.aspect
Moskovitz, Bob
Bob.Moskovitz at conservation.ca.gov
Wed Jan 21 12:52:09 EST 2009
Sounds like a great idea! If sometrhing like this can be done, we would have one less reason to shy away from FOSS.
> For my 2 cents worth, it seems to make a lot more sense for a
> *geographic* information system for all output to follow the same
> spatial organizational standards. I understand the history of
> the east
> is 0 convention for parts of GRASS. And I also appreciate the
> importance of not breaking code-dependent features within versions.
> However, that does not mean that we should keep a
> non-standard way of
> measuring direction for select modules (like r.slope.aspect), while
> measuring from north for others, simply because the program started
> out that way. Version changes are a time when we can rethink and
> standardize different modules that have evolved
> independently. Scripts
> are likely to break across the 6/7 transition for other
> reasons anyway.
> That said, a functionally simple approach that would not be quite so
> disruptive would be to add a flag to switch to count from east mode
> (with count from north as the default) or even a flag to switch to
> count from north mode (with count from east being the default if
> backward compatibility is indeed very important in this case).
> It is important to get an idea of how many things actually
> would need
> to be changed.
> Michael
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
