[GRASS-user] Problemas con inicio de Grass
Daniel Victoria
daniel.victoria at gmail.com
Sat Jan 24 11:37:36 EST 2009
By the looks of it it´s a bad gdal instalation. See if yoour linux
distribution supplies a gdal package and try to re-install it
Daniel
On Fri, Jan 23, 2009 at 7:11 PM, Milton Cezar Ribeiro
<miltinho.astronauta at gmail.com> wrote:
> (translation)
> Hi, I am new on linux and grass, and i have troubles when I start grass
> (version 6.2.3) a dialog box/window allow me to choose the project, but when
> I press start occurr the errors shown below.
> 2009/1/23 Luís Miguel Royo Pérez <luis.miguel.royo at gmail.com>
>> Hola, soy algo nuevo en esto de linux y grass, mi problema es el
>> siguiente:
>> Cuando intento iniciar grass (version 6.2.3), me sale la ventana de elegir
>> proyecto, pero cuando le doy a iniciar gras pasa lo siguiente, en la consola
>> aparece esto:
>> GRASS 6.2.3 (spearfish60):~ > g.region: /home/luis/fgs2/lib/libpng12.so.0:
>> no version information available (required by /usr/lib/libgdal1.5.0.so.1)
>> g.region: /home/luis/fgs2/lib/libstdc++.so.6: version `GLIBCXX_3.4.9' not
>> found (required by /usr/lib/libgdal1.5.0.so.1)
>> Error in startup script: can't read "monitor_zooms(1,1,n)": no such
>> variable
>> while executing
>> "lappend region $monitor_zooms($mon,1,$attr)"
>> (procedure "MapCanvas::currentzoom" line 13)
>> invoked from within
>> "MapCanvas::currentzoom $mon"
>> (procedure "MapCanvas::coordconv" line 23)
>> invoked from within
>> "MapCanvas::coordconv $mon"
>> (procedure "MapCanvas::create" line 68)
>> invoked from within
>> "MapCanvas::create"
>> (procedure "Gm::startmon" line 11)
>> invoked from within
>> "Gm::startmon"
>> (procedure "Gm::create" line 69)
>> invoked from within
>> "Gm::create"
>> (procedure "main" line 30)
>> invoked from within
>> "main $argc $argv"
>> (file "/usr/lib/grass/etc/gm/gm.tcl" line 521)
>> ¿Alguien sabe que es esto?, ¿Cómo lo puedo solucionar?.
>> Gracias y un saludo.
>> Luís Miguel Royo Pérez.
>> Licenciado en Historia
>> Arqueólogo colegiado Nº 16218
>> C/ Fray Junípero Serra, 70-13
>> Valencia, C.P. 46014 (Valencia)
>> Teléfonos 679846103 y 961331663
>> email: luis.miguel.royo at gmail.com
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
