[GRASS-user] re: Mac OSX- How slow can you go?
Hamish hamish_b at yahoo.com
Mon Jan 26 23:46:30 EST 2009
Macsurfcat wrote:
> I am running _OSX.5.6_ on an _intel_ _Mac_ using two (2)
> duo-core processors and a bunch of memory. I have set up
> GRASS 6.3 and it seems to be especially sluggish; i.e.,
> literally all night to import a vector shapefile, albeit a
> substantial one.
does the shapefile contain a rather long detailed polyline, like a
coastline?  if so search the mailing list archives for the "florida
coastline" problem.
at which stage does it stall? building lines?
> In addition, many modules (commands) will execute and then force an
> exit from the application, requiring a re-launch. Curiously, the
> tasks themselves are often completed.
that is not normal. are any error messages available?
by "application" you mean all of GRASS quits? Does it give you a "someone
is already using this mapset" error when you try to start GRASS again?
> The "brand" is *OpenOX Grass*, an "it requires no additional
> dependencies" package.
If there are build problems with that, we might be able help guess what
the problem is, but it is likely you will have to report problems
directly to OpenOSX as they do their building/packaging separately.
Hamish
