[GRASS-user] g.region, problem with projection
Andreas Neumann
a.neumann at carto.net
Wed Jan 28 01:36:04 EST 2009
Hi Glynn,
Here is what my WIND file looks like:
proj: 99
zone: 0
north: 1
south: 0
east: 743000
west: 707000
cols: 36000
rows: 1
e-w resol: 1
n-s resol: 1
top: 206000
bottom: 182000
cols3: 36000
rows3: 1
depths: 24000
e-w resol3: 1
n-s resol3: 1
t-b resol: 1
When creating the location and MAPSET I used epsg 21781 (the Swiss
coordinate system).
Then I checked the output of the env command. There is neither a
WIND_OVERRIDE environment variable set, nor a GRASS_REGION variable.
Do you see something wrong in my WIND file?
Thanks,
Andreas
Glynn Clements wrote:
> Andreas Neumann wrote:
>> I have problems with setting g.region - I always get an error message
>> like the follows:
>> region for current mapset <projection field missing>
> This error message indicates a missing "proj" key in the region
> definition (the WIND file, or a named region specified by the
> WIND_OVERRIDE environment variable, or the contents of the
> GRASS_REGION environment variable).
> The "proj" key is the first one to be tested, so if the region
> definition is completely empty, you would also get the above error.
> First, check whether either WIND_OVERRIDE or GRASS_REGION are set, by
> examining the output from the "env" command. Assuming that they aren't
> examine the WIND file in the current mapset. A typical WIND file
> should look like:
> proj: 1
> zone: 13
> north: 4928010
> south: 4913700
> east: 609000
> west: 589980
> cols: 634
> rows: 477
> e-w resol: 30
> n-s resol: 30
Andreas Neumann
Böschacherstrasse 6
CH-8624 Grüt (Gossau ZH)
Switzerland
Phone: ++41-44-2736668
Email: a.neumann at carto.net
Web: http://www.carto.net/neumann/
SVG Examples: http://www.carto.net/papers/svg/samples/
SVG.Open: http://www.svgopen.org/
