[GRASS-user] g.region, problem with projection
Glynn Clements
glynn at gclements.plus.com
Wed Jan 28 12:41:37 EST 2009
Andreas Neumann wrote:
> Here is what my WIND file looks like:
> proj: 99
> zone: 0
> north: 1
> south: 0
> east: 743000
> west: 707000
> cols: 36000
> rows: 1
> e-w resol: 1
> n-s resol: 1
> top: 206000
> bottom: 182000
> cols3: 36000
> rows3: 1
> depths: 24000
> e-w resol3: 1
> n-s resol3: 1
> t-b resol: 1
> When creating the location and MAPSET I used epsg 21781 (the Swiss
> coordinate system).
> Then I checked the output of the env command. There is neither a
> WIND_OVERRIDE environment variable set, nor a GRASS_REGION variable.
> Do you see something wrong in my WIND file?
No.
