[GRASS-user] starspan with grass support compilation failure
Maris Nartiss
maris.gis at gmail.com
Fri Jan 30 04:48:38 EST 2009
Hello Nikos,
probably create a trac wish report "Investigate Starspan integration
possibilities into GRASS". It can be used also later as meta bug to
track integration blocking code bugs.
I haven't used Starspan and currently have no requirements to do so,
still integrating various small projects into larger ones is a good
thing - lessens work fragmentation and improves code handling - any
GRASS dev can poke around that code.
Maris.
2009/1/30, Moritz Lennert <mlennert at club.worldonline.be>:
> On 29/01/09 20:06, Nikos Alexandris wrote:
>> On Thu, 2009-01-29 at 10:15 -0800, Jonathan Greenberg wrote:
>>> Folks:
>>> I would LOVE to see someone take over development on starspan -- I
>>> did submit a OSGEO application but it came back denied, more or less,
>>> because of lack of community support. There are a lot of bugs and user
>>> interface issues still remaining that would be nice to get cleaned up,
>>> but I'm not a C programmer and, while I developed the algorithm itself,
>>> I was not the coder.
>>> If anyone is interested in working on the development, please email
>>> me! If you all are not sure what STARSPAN does, it is a flexible way to
>>> get raster data (raw or summarized) associated with vector coverages
>>> (similar to Arc's zonalstats, although with more output types). E.g.,
>>> if you want to get the average pixel values from a SET of raster images
>>> underlying a single vector coverage, starspan will spit out a CSV
>>> containing the vector's original database, along with a column for the
>>> average pixel value for that polygon. The algorithm tends to be very
>>> fast, especially in cases where the polygon coverage is a fraction of
>>> the raster coverage (which tends to be the case in many problems).
>>> --j
>> Jonathan + all,
>> please excuse my ignorance if I ask something that I shouldn't: could
>> you imagine starspan as part of GRASS? Something like "v.starspan" ?
> http://lists.osgeo.org/pipermail/grass-user/2008-July/045882.html
> http://lists.osgeo.org/pipermail/grass-user/2008-August/045886.html
> +1
> Moritz
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
