[GRASS-user] link to datasets from other locations?
Wed Jul 1 12:08:36 EDT 2009
Timmie wrote:
> >> How do I link to a raster and vector data in another
> >> location presuming it has the same projection?
> > add the mapset as a symlink to the mapset in the other location,
> > then use the @othermapset notation.
> So sharing data between locations is not really supported?
> Even if I just want to add the layer to the map view?
The only operations which access data in a different location are
those where the data is necessarily in a different location because it
uses a different projection, e.g. re-projection or rectification.
In general, if it's possible for the data to be in the current
location, then it must be.
