[GRASS-user] link to datasets from other locations?
Hamish
hamish_b at yahoo.com
Wed Jul 1 11:02:33 EDT 2009
Timmie wrote:
> So sharing data between locations is not really supported?
Not at all supported. (except for v.proj, r.proj, i.rectify)
> Even if I just want to add the layer to the map view?
if you want to mix things you must use multiple mapsets from the
same location with @othermapset.
perhaps you could sneak a way with r.external using the GRASS
GDAL driver plugin?
Hamish
