[GRASS-user] Problems with v.in.ogr importing shp files
Jhon Ortiz
eljhonjhon at hotmail.com
Wed Jul 1 21:11:53 EDT 2009
> Hi all.
> Compiled and installed Grass 6.5 from source on a 64x Ubuntu 9.04
> machine. It seemed to me it worked fine but when I tried to import the
> curvespear shape file (following the step by step tutorial
> http://www.ing.unitn.it/~grass/docs/tutorial_62/index.html ) by v.in.ogr
> function, the procedure didn't go on. In the output window:
> Layer: curvespear
> Importing map 1755 features...
> and nothing else.
> The imported file is in the right place but with nearly no feature inside.
> I'v been looking for a tip in the user mailing list archive but Rafael
> Moraes suggestion doesn't help. Added http://les-ejk.cz/ubuntu
> repository to source list and reinstalled gdal... but nothing happend.
> The same with Grass 6.2.3. (Maybe I made some newbe mistake in
> updating gdal).
> Any suggestion?
> Thank you.
> Ferro
> P.S
Hi all,
I have the same problem when I tried to import the shapefile with v.in.org
I'm working with GRASS 6.4.0svn on a 64x Ubuntu 9.04
In the terminal give this errors
GRASS 6.4.0svn (Prueba_location):~ > *** buffer overflow detected ***: v.in.ogr terminated
======= Backtrace: =========
/lib/libc.so.6(__fortify_fail+0x37)[0x7f95d00bc2c7]
/lib/libc.so.6[0x7f95d00ba170]
/lib/libc.so.6[0x7f95d00b97ab]
/lib/libc.so.6(__snprintf_chk+0x7b)[0x7f95d00b967b]
/usr/lib/libgdal1.5.0.so.1(_ZN10OGRFeature16GetFieldAsStringEi+0x346)[0x7f95d0de2296]
v.in.ogr(main+0x2284)[0x406b50]
/lib/libc.so.6(__libc_start_main+0xe6)[0x7f95cffdb5a6]
v.in.ogr[0x403969]
Some advice?
Thaks
John Ortiz
_________________________________________________________________
Llévate Messenger en el móvil a todas partes ¡Conéctate!
http://www.microsoft.com/spain/windowsmobile/messenger/default.mspx
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090702/b6a3a44b/attachment.html
