[GRASS-user] r.mapcalc problem ?
Juan Carlos Torres
jctorres at ugr.es
Thu Jul 2 14:02:51 EDT 2009
Hi Martin
I think that your second command is correct. That is
r.mapcalc 'test = if(mydem < 0.0000,mydem,null())'
Probably your problem is that your are drawing the new map on top of the
older one.
Just try to erase the monitor before drawing
d.mon start=x0
d.erase
d.rast test
Juan Carlos
Martin Laloux escribió:
> Excuse me if I seem stupid but I have a problem with r.mapcalc. I have
> a dem stored in FCELL with range of data(z) : min = -26.670000 max =
> 695.960022 . I try to extract a raster/dem with all values < 0.
> I try
> r.mapcalc 'test = if(mydem >0.0000,mydem,null())'
> Results give me
> Range of datafor test : min = 0.200000 max = 695.960022
> with r.mapcalc 'test = if(mydem < 0.0000,mydem,null())'
> results
> Range of data: min = -26.670000 max = -0.010000 -> ok for me
> But when i display test map, i allways get the full dem and not only
> a map with values < 0.
> I try replacing test with MASK but same result
> What is the error I made or how can I do ?
> grass-user mailing list
> grass-user en lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-user
