[GRASS-user] r.mapcalc problem ?
Thu Jul 2 17:56:19 EDT 2009
Juan Carlos Torres wrote:
> I think that your second command is correct. That is
> r.mapcalc 'test = if(mydem < 0.0000,mydem,null())'
> Probably your problem is that your are drawing the new map on top of the
> older one.
> Just try to erase the monitor before drawing
Or use "d.rast -n ...", which will draw null cells.
